cd writer not burning songs on disk .... help!
mythos4sl
Hi guys!
I have a problem that ive had for a while and i finally wanna fix it now! I have a samsung writemaster that could copy any make or model of cd but the problem is it doesnt. I used nero a couple of times on blank disks to make mp3 cds and doesnt work and now i tried using itunes and that doesnt work either. i must have waisted about 10 cds trying this out. Please can some1 help me with this problem? any further info .... just ask :0
thx guys!
When you make the mp3 CDs, you say it doesn't work. Does that mean the songs are on there but just not playing in a mp3 player or...? Are you using the correct Nero option?
Hi guys!
thx guys!
1st go buy one RW disc, so if the write farked up you just erase and try again. I think the fact that you did the same thing like 10 times, you must be doin the same "wrong" thing ?!?
Using nero: for an MP3 disk (not converting to CD audio)
1 open nero burning rom (not the irritating wizzard)
2 create a new ISO cd
3 drag and drop the songs (or use the add files) into the main window (2nd one of the four)
4 dont add to many or overburn
5 click the burn icon - uncheck simulate burn to disk (try not use full write speed - helps some times)
6 try play back or explore once finished....
PS some older mp3 players don't like vbr mp3's, but I doubt that will be an issue here...
also if you multisession the disk, it can be problematic - allthough i haven't experienced that!
u see i have dont that .... exactly like u say .... ive updated the firmware on the cd drive, i can see the songs on the cd but when i put it into my cd player it playes it for like 2 secs and then it tells me there is an error. I cant be doing anything wrong because even off itunes i tried to make a cd off my playlists and it does the same thing .....
^ lol, yes they are pretty cheap these days...
...quick question, after burning the disc, how to you test it - ie in a cd player or in the drive that you used to write?
as said above also, try and reduce the writting speed
Rip CD with Windows Media Player and highlight MP3's + drag to CD?
Easier than Nero
