cell c data usage monitor
I'm sure you should check in the cell c forum. But depends if u prepaid or contract. I'm prepaid and can use USSD *147#. Or register on the cell c site by mycellc then you can see all that info.
Hey, Sorry to revive this old thread. Is there detailed usage? All I can get on the website (and USSD code above) is my balance.
Would like to see how much I used each day. Something like Afrihost client zone. Even FNB Connect had that data, but had to use banking app or website to track usage. Surely the data is there. I just cant access it?
Also: Is whats app data free or not? Where do I see what I used?
https://www.cellc.co.za/cellc/cellc-app
You can monitor your data usage there, however it only monitors accumulative data usage. Their app leaves a lot to be desired.
My Data Manager is one of the better Android apps for monitoring your daily data usage. It is however, not directly linked to your actual account usage - so be aware of that.
You need to be on a WhatsApp bundle for zero rated WhatsApp data.
https://www.cellc.co.za/cellc/bundles-contract-detail/Whatsapp-Bundles
OK, that sucks. I have the sim in a router: PC, tablet and mobile all connecting through the router... Guess I have to monitor it on the router...
If you register your SIM on the Self Service menu on Cell C's website, you can definitely monitor usage remotely, but unfortunately only accumulative usage for the month is available.
