Centurion, EXT ANTENNA??
FISHborn
Is there anyone staying in Centurion or near Zwartkopx7 (Hennopspark side under highway), that are willing to borrow me their antenna for an test. Just want to see if it is worth buying an antenna. I have 1 bar signal not even enough to connect...
With the external antenna ur getting 1bar signal or without?
Considering external antenna would be only slightly better but not worst...it might pick up a good signal and when it do so you will have much faster speeds and much stable connection...
There was example with CraigSa he bought an external antena and he says that there has been a big improvement over his speed..now he is happy...
If u r looking for advice i would say just go for it...get the antenna try it out if it works buy it if it doesnt take it back...but im sure it will work at least to get 2-3 bars more...:P
ok now i'm not 100% sure on the following as I have no need for an antenna but I read somewhere on this forum that if your speeds are really bad, or signal is really crappy that you can get one for free
My signal is without an antenna. But i'm sure i can get some signal with it bec i def see 1 bar 50% of the house, and when i try to connect the signal drops to 0. I hope Interprise has a return policy... LOL!
