Hey guys,
So as some of you know, I ride a 250cc motorbike.
It's a 6 speed, but fairly short gearing sees it top out at about 145. However, with the redline starting at 10,000RPM, this means that at 120 I'm sitting at 8,000RPM. Obviously this is pretty harsh on the engine, as well as the fuel consumption.
So, I have been thinking about playing with the gearing to alleviate this.
The current ratio is 2.846(37/13).
So, was thinking to go maybe 35/13 (2,692).
According to http://www.gearingcommander.com/ this would increase theoretical top speed from 158.5km/h to 167.9km/h, which should drop my revs at 120km/h from about 7,500 to about 7,100.
My question is, have any of you done something like this, and were there any tangible differences, or anything you would recommend watching out for?
