Checking LTE speed before committing to a contract
Suurlemoen
Hi - I'm still trying to figure out what connection option is best for us. I'm looking into LTE from the various service providers.
So far I've discovered that we are not in range to get Rain LTE.
Webafrica, Afrihost, Cell C have all told me that I can't get reliable LTE from them as we're not close enough to a tower.
Only Telkom LTE seems to be possible, according to their coverage map. One of my neighbours uses Telkom LTE and says she has "no problems". I'm going to ask her what kind of speeds she gets, but in case I can't get that information from her, is there any other way I can check the Telkom LTE connection and speed without actually committing to a 24 month contract?
Thanks!
[XC] Oj101;21472383 said:
Prepaid SIM card?
This - get a bunch of cards, load a bit of data, and test.
Sorry for being dim...how exactly do I do this?
Buy a prepaid telkom sim card. Should I put it in my wireless router? (I do have one) Or my phone?
I don't always believe the map maybe try find some one with such get them to come around to test.
I'm not sure what the best device to test with is, probably the one that gives you the most detailed information regarding signal strength?
buy a HUAWEI B315 LTE from Gumtree. buy sim cards from each provider at checkers load 200 MB - 1 GB Data. do speedtests with OOKLA speedtest app
Remember to connect to your router with an Ethernet cable, otherwise any glitches on your wifi affect your speedtest result.
