Choosing a power supply
mosquito5
Krugersdorp
I am looking to buy a pc from take2 where they have an option to buy a customise a pc that comes with a Thermaltake LitePower - 700Watt Power Supply Unit. Is this a power supply?
Thermaltake is a good brand. Don't worry too much about that...
Antec is the best IMO...
LitePower's are crap IIRC. We cannot advise you without listing the specs of the PC. In any case, get Corsair.
Rather build up a pc with the components you want and pay for the place to assemble it unless you don't mind doing it your self..
I know Prophecy builds for you, and a few other places..
Give us your budget and we'll make a plan for you :)
If theyre including a 700w thermaltake in a r4-5k build I'd be pretty happy with that. You can't get too much power draw for that kind of budget. That unit will be more than adequate. If you need to buy a PSU separately, there are probably other models you could consider for the same price. Which one is the case?
