Hey guys,
So Ive just moved into my new house and am having wireless reception issues. The house is 2 stories, and the ADSL modem and switch sits pretty much in the middle of the hosue on the bottom floor. I am using a Linksys Cisco X3000 router and the wireless reception is pretty poor around the house. I used this router in my previous house and always had great performance from it, so I am assumign that due that the steel support structure used in the house is causing the poor signal quality. I cant even get decent signal in the room next door to my router.
At my work place, our IT department installed a Cisco Aironet 1040 Wireless Access Point - and this thing is bloody brilliant. I get good wireless access about 200-300 meters away from the device on a different floor, through several brick walls and the concrete floor, and severe RF interference created by the printing presses in the factory below me. I would like to use this same device in my house due to its great performance.
Firstly, do you think this device will give me better reception than the regular Linksys Cisco home-use routers? Where do I buy this device in SA? I could ask my IT guys to order one on my behalf, but I would prefer to buy it on my own. Lastly, which model should I go with, and how easy is it to install? I have a Linksys Cisco 8-port switch to which my whole house is networked to, and this is currently connected to my Linksys Cisco X3000 adsl model router. I was thinking I would disable wifi on the X3000, and connect the aironet device to the X3000, which would serve the wireless to the house. What do youll think?
Any help would be appreciated.
