Cisco Help!
Cash12
Hi Guys, i have a cisco adsl router,
Can anybody help me with a config file? I am with mweb at the moment.
The config file i am using doesnt seem to be working that well, i seem to be dropping connection everyday at around 8 0 clock, have to reboot the router...also at random times dhcp just stops, so all exsisting pc's on the lan work, but if i go home and my phone wants to connect it doesnt, just says obtaining ip..aswell as if i do a release and renew on my pc it wont renew, have to reboot the router.
Any assistance would be of great help.
here is my config file:
service timestamps log datetime msec
no service password-encryption
hostname home
boot-start-marker
boot-end-marker
logging message-counter syslog
enable secret cisco
no aaa new-model
dot11 syslog
ip source-route
ip dhcp pool LAN
network 10.10.10.0 255.255.248.0
default-router 10.10.10.1
dns-server 196.28.80.139 196.28.80.140
ip cef
ip name-server 196.7.0.138
ip name-server 196.7.142.132
l2tp-class dsl
authentication
hello 5
password ****
vpdn enable
vpdn-group pppoe
! Default L2TP VPDN group
accept-dialin
protocol l2tp
archive
log config
hidekeys
pseudowire-class test-dsl
encapsulation l2tpv2
protocol l2tpv2 dsl
ip local interface Dialer1
interface ATM0
no shut
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
no ip mroute-cache
load-interval 30
atm ilmi-keepalive
pvc 8/35
pppoe-client dial-pool-number 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Virtual-PPP1
ip address negotiated
ip accounting output-packets
ip mtu 1452
ip flow ingress
ip policy route-map clear-df
no ip mroute-cache
no logging event link-status
no peer neighbor-route
no keepalive
no cdp enable
ppp chap hostname (isp username)
ppp chap password 0 (isp password)
ppp pap sent-username (isp username) password 0 (isp password)
pseudowire 196.30.121.42 10 pw-class test-dsl
interface Vlan1
ip address 10.10.10.1 255.255.248.0
ip nat inside
ip virtual-reassembly
interface Dialer1
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
encapsulation ppp
dialer pool 1
dialer idle-timeout 30
no cdp enable
ppp ipcp dns request
ppp ipcp address accept
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 196.30.121.42 255.255.255.255 Dialer1
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer1 overload
access-list 1 permit any
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
password cisco
login
scheduler max-task-time 5000
end
Under your VirtualPPP interface please try removing this:
ip mtu 1452
and add this :
ip tcp adjust-mss 1452
Also please post the IOS version in use by using "sh version" command
Caleb
Thanks for the reply, the version of ios is 12.4
I will try what you have suggested when i get home this evening.
