Hi Guys
I need some help
I have a routing problem with a cisco 1800 Router
Its quite a simple setup but my Cisco skills are not that good and I don't know how to solve this
I have a internet line and the ISP put the router in its a oneaccess one150 router.
I take a line from that router switch port to a Cisco 1800 Router Ethernet 0/1
I then take another line from the Cisco 1800 Ethernet 0/0 and connect it to a Cisco 2950 24 port Switch
I have cleared the config on the switch so its just a plain layer 2 switch with no Vlans ans so on
I can ping the ethernet 0/0 and ethernet 0/1 ports from the 2950 switch no problem
The problem I am having is I cannot ping the ISp's router through the switch I can ping the ethernet 0/1 of the router but not the ISP's Router
I can ping the ISP's router from the telnet interface of the 1800 Router but not if I am on the 2950 Switch
Here is my config I have changed the ip's to fake ones but it should give the just of what I am doing. Please tell me if there is anything that could be causing this problem.
Building configuration...
Current configuration : 2693 bytes
version 12.4
service timestamps debug datetime msec
service timestamps log datetime msec
no service password-encryption
hostname router
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
resource policy
clock timezone gmt 2
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.0.1.0 10.0.1.99
ip dhcp pool gwpool1
import all
network 10.0.1.0 255.255.255.0
default-router 10.0.1.1
dns-server 41.160.0.36 41.160.0.37
domain-name domain
ip domain name yourdomain.com
ip name-server 41.160.0.36
ip name-server 41.160.0.37
interface FastEthernet0/0
ip address 10.0.1.1 255.255.255.0
ip nat inside
ip route-cache flow
duplex auto
speed auto
interface FastEthernet0/1
ip address 41.180.35.34 255.255.255.248
ip nat outside
ip route-cache flow
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
clockrate 2000000
ip classless
ip route 0.0.0.0 0.0.0.0 41.180.35.33
ip flow-export source FastEthernet0/0
ip flow-export version 5
ip flow-export destination 10.0.1.40 2065
no ip http server
ip http access-class 23
ip http authentication local
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 160 interface FastEthernet0/1 overload
ip nat inside source static tcp 10.0.0.40 21 41.180.35.37 21 extendable
access-list 23 permit 10.0.1.0 0.0.0.255
snmp-server community public RO
snmp-server community private RW
control-plane
line con 0
login local
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet
line vty 5 15
access-class 23 in
privilege level 15
login local
end
I need some help
version 12.4
hostname router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
no mmi pvc
ip subnet-zero
ip cef
import all
domain-name domain
ip nat inside
ip route-cache flow
duplex auto
speed auto
ip nat outside
ip route-cache flow
duplex auto
speed auto
no ip address
shutdown
clockrate 2000000
ip classless
no ip http server
control-plane
line con 0
login local
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
login local
line vty 5 15
access-class 23 in
privilege level 15
login local
end
