Cleaning cloth for iPad?
Hemps
Slummies
I have been using a couple cleaning cloths but none really work well, a lady in my office bought a ACER Tablet and it came with a cleaning cloth that worked wonders?
Anyone know where I can get a decent cloth from?
Online or from a shop?
Specsavers?
micro-fibre cloths from PNP work well.
Also - if you bought an apple smart cover you can run the inside of it up and down like a squeegee.
http://www.expeditionexchange.com/microfiber/
This is the cloth I currently use, still smudges.
the one that came with her tablet one single wipe and everything's gone
Hers almost looks like this:
http://www.expeditionexchange.com/microfiber/microfiber004%20041.jpg
My MF cloth does not look exactly like that. Mine is a bit "rougher". Not so smooth.
Perhaps just get one from PnP or a Crazy Store and check if it makes a difference. Mine was in the kitchen section when I bought it. If that helps at all.
