So I had a old pc lying around and our router is terrible at QoS so I decided to set the old pc up as a gateway to do the QoS. So I looked around and decided to use ClearOS as it seems a good option.
So I got an extra PCI Lan card and stuck it in the PC. I set it up as follow : Netgear ADSL router -> Gateway PC with ClearOS on -> D-Link Gigabit switch (with all PC's on). Now I installed ClearOS and everything worked fine.
I set up eth0 (connected to ADSL router - ie. external) as a ppoe connection (it was then renamed to ppp0), this worked fine and it shows my external ip as 41.xxx.xxx.xxx. Then I set up eth1 (connected to switch with PC's connected to it) with IP 192.168.0.255 and configured it as the DHCP server. This worked well and the PC's connected to the switch all detected their IP's and Default Gateway successfully.
Now I'm only having 2 problems :
1.The 2 windows PC's (Win 7) detected each other but neither could detect the Gateway (I assume they should be able to detect it as I've read that you can configure ClearOS remotely)
2.Although the Gateway has a pppoe connection and a external IP and it is connected to the PC's and gives them their IP's, I still dont have internet access through the PC's behind the gateway.
I'm new to linux so please excuse me if I missed something simple
I'll appreciate any assistance
