COD4 with Mweb Uncapped Issue
SHiFTa
Sup all
I got a issue when I play COD4 with my new Mweb uncapped account.
I can join servers but stay connected while in spectate mode. As soon as the round ends and starts a new round, I get Disconnected.
DSL account is on the router.
Thanks in advance.
ShiFta
This happens to alot of people, Including me and I'm on Telkom 386kb/s 3gb cap.. sigh..
I fixed it by opening ports, turning off firewalls in the router, enabling uPnP, everything you need to do to open your NAT..
Try to google "How to Open NAT in MW2" that should show you the way. :)
Yo, thanks for the reply.
I have enabled UPnP,NAT(was on) and created a DMZ for my IP. I have even manually added the routes into my PC.
63.146.121.11,255.255.255.255
63.146.121.12,255.255.255.252
63.146.121.16,255.255.255.240
63.146.121.32,255.255.255.224
63.146.121.64,255.255.255.192
63.146.121.128,255.255.255.128
63.146.122.0,255.255.254.0
63.146.124.0,255.255.255.240
63.146.124.16,255.255.255.252
63.146.124.20,255.255.255.254
I have also opened up my Firewall completely, allowing everything incoming to my IP.
Still not working! Ahhhh! :(
It seems to only occur when I join I-Game server. SGS is working 100%.
Fixed it by replacing my new Netgear DG384 router with my old Zyxel Router.
Ahh. Also if you want to still give it a try. Go to www.portforward.com or just google port forwarding, then find your router, follow the instructions, then after that you can check out how to do it with COD4 specifically. Go check it out. Just google "Port Forwarding"
