I'm on local cap so I can't research, but this is what I know.
First of all, the bluetooth button on most compaqs also doubles up as the WLAN button, so if bluetooth is off, wireless should also be.
Then, if you are using Windows XP, go to "network connections" in control panel, right click on "Wireless Network connection" and then you can enable or disable.
