Computer off while LED on USB still flashed?
kaisterkai
Good day..
I just to know something...
When I switch my computer off... My USB wireless LED still remains on... Along with my mouse LED scroll button...
I just want to know if there is anyway to change the option to make it switch off... Because on my brother s computer, it doesn't have that... (And I'm sure on most computers as well... )
So I just want to know if it is possible to switch it off...
Will be a setting in the BIOS somewhere. What motherboard do you have? Though I do find it strange the the mouse stays on. Is the USB wireless thingy for the mouse, or for wifi?
I have a H55M Gigabyte motherboard... yeah the mouse LED is on as well.. Kind of annoys me because my computer is in my room and then I have this Wifi LED flashing all the time and the mouse light on.. Will check in the Bios settings.. But where will it be under?
Check your power options in control panel, it looks like the method you are using to switch the pc off is making it go to sleep mode on power off.
Tried this, and it doesn't have any options that I can find...
Thanks anyway.. ^ ^
unplug the power from the wall socket then press the power button of your pc to flush out the power, it happens sometimes. then plug it back in and see if the problem persists the next time you switch it off.
I have the same thing, i find within a minute or two the device shutdowns/ light turns off
But it happens all the way through the night.. Like it's still on the next morning... But will try...
