Configuring Sunsynk from phone or PC possible?
I want to update my settings remotely (LAN is fine). Is it possible with Sunsynk and what do I need?
I have wondered the same thing.
I believe the best way is with Solar Assistant and Raspberry Pi.
Maybe someone else has a better idea.
I update mine via sunsynk app or web. Using the sunsynk data logger. I think, but stand to be corrected, you can do it via solarman businness as well?
Will depend on which connector you have. there are two.
One is compatible with SolarMan (the older model), and the newer model compatible with the Sunsynk app.
The newer adaptor on its own is about 2k+vat at dealers, so probably 2500ish retail.
No need to use sunsynk, solarman adapter + solarman business set up is all you need.
I have Solarman Business but I haven't see any way of changing settings remotely.
With home automation in mind, I will definitely plan to get Solar Assistant.
You need to go to edit your devices and change it there but don't think you cna do this with automation.
