Connceting wireless through a HUAWEI Router
zegen
Can someone help me.. I am on uncapped ADSL and my I am trying to connect to wireless with no success. I can pick the wireless but when I put in the password i get a message that I can successfully connect to wireless. Please help!!!!!!
Hi Zegen,
We are going to need a little bit more information.
I would suggest that initially you try and connect without a password. So take the password off the router and try again.
If that does not work then let us know the model number of the router.
If it does work then put in the password again and try and reconnect. Remember passwords are case sensitive.
Regards
Tim
