Neither as far as I can see. You could try http://www.dbg.co.za/product_info.php?cPath=1_55_65&products_id=692 though.
You are wrong the mikrotik can load balance, and those 750's are perfect for the job.
I actually prefer the mikrotik routers, that RB750 has 5 lan ports so you could actually setup 5x iburst routers on it and have the whole shebang load balance across all 5 (you would need 2 account, 3 modems per account)
there is difference in memory/cpu/port speed between the 750 and the 750GL,
following is the major difference.
750GL = gigabit , 64MB memory
750 = 10/100Mb, 32MB memory
memory depends on how much firewall/mangle rules you setup, i have a ton and still have a lot left.
the gigabit lan is nice to have faster transfers between server/desktop/laptop.
what I am really missing is a wireless connection, there is new models out like the 754GL with wireless, just haven't seen their prices yet.
these devices are actual routers very powerfull, the other stuff that I see I consider as toys.
OK, thanks to you I've managed to acquire a RB750.Yes, it is not easy to use for the first time but it grows on you...
Now I wonder if you would be so kind as to pass on the setup instructions to configure the unit to accept 2 x wan port inputs.
Thanks!
The RB750 has been mentioned before and looks like it should work. Apparently, any router that has RouteOS on it should be fine.I have a hp procurve 408 J4097B with 10/100base TX Ports, will this work?
I found a RB750 will this maybe be a better option for me than my HP??
AFAIK, you can't connect two USB cable modems to the PC (only one will be picked up). You should be able to connect and bridge two Ethernet connections (provided your Mobo has two Ethernet slots).....or will it also work if I connect both modems to my PC via usb cable and just bridge the connection?
Yes you can. I'm doing this atm on my work PC and two home PCs without any issues.And I was told you can use up to 3 modems per account. Can I use all three modems on different computers with my same log-in details at the same time?
