here's another idea that won't require much programming in android:
- android device/phone with Macrodroid or Tasker or similar
- dummy 12V wifi modem
1) hook up the wifi modem to the 12V output on the alarm (you may need to fiddle with electronics here and maybe put a relay so that when you get the alarm signal, the relay switches on the wifi modem on and keeps it on for a few minutes
2) on the android phone in Macrodroid or similar, set the wifi network appearing to act as a trigger, and set the task to whatever you want - in this case, make a call, send an sms, send a whatsapp message to your phone number
not much programming needed but perhaps a small relay/timer between the alarm unit and your wifi unit.
@WireFree - i've been looking for programmable gsm modules, but i have seen anything but cheap (cheapest i've seen was R1,300 and up IIRC). Are there any cheap cheap gsm modules one can find (even if they are second hand)? If so please share? Thanks!
