Mal1ce
Customer is looking for a way to connect his PA system in his factory to his new SIP cloud PABX system, so he can remove the need for higher level staff members to have separate microphones at their desks to address workers in the factory.
Yealink phones on the desks, PoE switch in the rack. Pretty sure the cloud PABX provider can setup a paging extension without hassle. PA system has an amplifier with 4 microphone inputs and 4 horn speakers attached to it.
So far Google has turned up this: https://www.vikingelectronics.com/products/pa-ip/
Just wondering if anyone on here has accomplished this and if so what components you used?
Thanks!
Thanks!
