Connect Wireless Router to Powerline adapter
milan188
Can Anyone assist me in setting this up. I connected the ethernet cable to the lan port of the router. turned dhcp off and played with the ip settings but its not working
A suggestion. If you access the router admin you should change the router to the same ssid
