Connected but not connected
losadel
Hi guys,
I've got a bit weird problem with a family members adsl. The router connects to the ISP(Telkom*spit*) but when I ping any host name it resolves the IP but I'm not getting any ping replys.
I've tried pinging local and international sites, same result.
I've tried using a different account(an IS account), same problem.
Disabled the firewall, no luck.
and out of desperation I phoned *correction* trieded to phone telkom but all I got holding music.
Do any of you know what might be the problem.
ps. its a mega 105 wr router
Thanks.
I had the same problem with Netgear. Is shows connected but could not browse anything. Even with different IS/SAIX accounts.
Had to do a hard reset , there is a small reset button on the Netgear. (switching it off doesn't work).
Hmm, looks like my solution didn't work ;) btw if TelkomUseless's solution doesn't work, go borrow a router at my old place - I doubt they still use it :)
TelkomUseless: forgot to mention, I did that aswell but to no success. thanks
AxisK: shot dude might take you up on that offer. I'll give you a ring if I can't get it sorted tonight.
