My guess is that your neighbor has ADSL, most of the Telscum routers with wifi are marconi ones. And the low signal part is prolly cos they are next door!
Im sure you cant pick up and IP tho, because they are most protected with WPA or WEP64 keys. The windows zero configuration utility will try and connect to it becuase its stoopid!
