Connecting analog x ray to pc or dvr
Roean
Upington
Good day all
Not sure if this is the right thread but anycase.
At work we are looking to connecting a x-ray with either a computer or an analog dvr. The dvr looks like the easiest option at the moment.
Now my question is, can a dvr take any input or must it be a cctv camera?
And for pc, where can I find a card with bnc connectors, as it is kinda difficult locating one on google from ZA?
Thanks in advance
I also looked at those things, but their problem is that they have a too low resolution, so you will lose image quality. But thanks for the suggestions
That is a brilliant idea!!
Then we can get full images on the ip without loss.
Thanks very very much
Google Video BNC to Ethernet, use it like an IP Camera.
4 Channel Passive Video BNC to UTP RJ45 Balun Transceiver https://www.bidorbuy.co.za/item/265..._Video_BNC_to_UTP_RJ45_Balun_Transceiver.html
Nope. That simply converts the BNC signal to travel over Cat5 cable. That is, an ANALOGUE signal using the various pairs. It is not actual Ethernet.
@OP, what kind of video output does the xray have? What resolution do you need?
Ultimately, you will need to establish two things:
- one, analogue conversion cables from whatever your xray outputs to whatever your video capture solution is able to accept
- two, a video capture solution that gives you the required resolution from your source (obviously, limited to the max resolution that the source can offer!), and can provide it as a digital file or stream.
- three, a software solution that can drive the video capture device, and save the files/streams appropriately.
If you can, please provide details of the xray system, so I can see what the outputs are.
The xray only has a bnc connecter for output, which I assume is analog, as no bnc is digital.
There is and spdif ouput on the screen, which I also assume is for screen sharing, which could also work with modern tv cards.
The xray system uses a memoskope for storage, but the system we have unfortunately dies not have one, and a new one (or refurbished) is the same price as the whole xray, thus why we just want to connect a pc and then save it as is.
For the resolution it can output HD according to the technician which I hope is full HD. I do know that a memoskope saves the image as a 20mb file which it converts to a lossless jpeg of around 8mb, so the resolution is HUGE.
I like the ip idea of DanDango as you don't need a tv card (which then requires a tv licence, thanks SABC) to few the image. But you do make a good point of getting a analog to digital converter.
FYI the xray is a Siemens Siremobil Compact L, which must be a secret cause Siemens gives little information about it. Note: this is a 2005-2008 model so it is not brand new
I think you need to post pictures of the connectors that you think you can use, and any labels that there may be. SP/DIF is not for video, it is for Audio, so I'm really not sure what that is about.
I know this post is dead, but I would like to post my results.
I bought a tv tuner card for the pc, connected the x ray machine from it's analogue output (for a third screen) to the tv card and got digital imagery like that.
Unfortunately the pc got struck by lightning, and then the xray machine 2 months later. But got it working
