Connecting Centurion D5 motor to lights
zakslaher
Hi,
I have a centurion D5 sliding gate motor. It has the connections to connect a lights that will switch on when the gate is opened.
How do I wire this to the lights. I diagram will be helpful
Hi,
The D5 or the D5 Evo? The D5 doesn't look like it supports lights according to the manual. The D5 Evo does.
I am not an electrician so take this with a pinch of salt. I do not know what I am talking about.
Neutral and earth get wired to the light directly. Live goes from from the circuit board (the terminal labeled light) to the light itself. Should be as easy as that but again I have absolutely no clue.
Why not just permanently wire the lights to a day/night switch?
