Connecting Electrical Relay Switches to SP6000
cenredash
Hi there
I've got a Paradox SP6000 and want to add IP150 internet module to do some basic home automation.
I was told by the consultant that I could get my house outside lights connected to the board via the Programmable modules PGMs and be able to connect the lights to that so I can switch them off. Could also, for example open garage doors.
What I need to know is how much it would cost (to get an electrician) to get a relay switch from the original light switch to the board so that the security guys can hook this up.
I'm also interested in, for example if the outside alarm triggers that the outside lights go on automatically.
Anyone have information on this? including the electrical wiring bit? Will my light switches work as per normal?
CA
