Connecting GPRS with EDGE
louisp
Hi,
I'm trying to connect 2 PC's. One is a Laptop with an Edge card, the other is a PC with a cable connect to gprs phone.
Both PC's can ping sites and even other PC's. but I can't get them to ping each other.
Firewalls are off.
It seems that MTN is dropping the packets on the third hop.
Any Advice??
Tracing route to 172.24.30.*** over a maximum of 30 hops
1 * * * Request timed out.
2 898 ms 359 ms 223 ms 196-11-245-209.mtn.co.za [196.11.245.209]
3 725 ms 359 ms 259 ms 196-11-245-214.mtn.co.za [196.11.245.214]
4 * * * Request timed out.
5 * * * Request timed out.
6 * ^C
thx
AFIK the MTN network uses NAT (Network Address Translation).
That means that all MTN users have the same IP address outside the MTN network. NAT sorted out where incoming trafffic should be routed to inside the MTN network.
The bottom line is that you cannot ping a PC on the MTN 3G/EDGE/GPRS network.
For more information about NAT see:
http://en.wikipedia.org/wiki/Network_address_translation
Thx,
That would make sense.
I thought it was some internal firewall/proxy blocking the ping requests. It could be true, allthough it didn't appear to be as both PC's reported different IP's.
Is no one on EDGE then able to setup home web pages, alarm systems, remote desktop, etc?
You need an internetvpn apn AFAIK. Call them and ask for one. Haven't used it myself though.
Phoned MTN:
Apparently this will cost alot :(
I'm out of options...
Will try freeVPN next but I'm not hopefull
