connecting my front usb ports
wizdumb
now randburg
so i never got around to connecting my 2 front usb ports well due to not knowing how to.
so if someone can please assist me
my mobo: gigabyte G31M-ES2C
pic here : http://www.pc028.net/images/200812/goods_img/399_P_1228174936611.jpg
the case has 2 sets of small cables that are connected to the usb slot, there are only 4 small wires marked (white = port -, red = VCC, black = ground and green = port +) on each cable
so if someone can please tell me how to connect it so that the front usb's work
i'm thinking it goes where the mobo states F USB1 and F USB2, but each of those has 8pins
Yes F USB 1 and 2 should work. Have a look at your motherboard manual, it should show you exactly where the pins should go.
the manual doesn' actually state where the cables should go... :(
thanks computek, let me try what you suggested
[edit] tried it, and it worked..thanks again
