Hi all,
I need some help with my adsl connection - so of course I'm turning to the experts at MyBroadband
Problem 1 is that my router frequently loses connection with my ISP, and I need to reboot it to get it to reconnect and authenticate (this happens at least daily).
Problem 2 is that frequently the lights on the router indicate that everything's fine, but the connection is just so slow that it looks like it's disconnected. I can't even load google's website, and if I ping www.google.com, I'm losing 50% of the packets.
I don't really know where to start looking for the problem. It's not my laptop, because the same thing happens on my phone. And it's not my ISP, because while it seems to be worse if I'm using my fnb connect account, it also happens a lot using my afrihost account. It's not the wifi signal from the router, because it's on a channel that doesn't overlap any of the neighbours, and the signal strength is good.
It seems to happen the most during peak evening time, but then that's because that's when I try to use it the most.
Could it be my router? The adsl/pots filter? The cable connecting the router to the phone jack? I get a LOT of crackling on the phone connected to that jack; could it be noise on the line? Is it just that both ISPs get overloaded during peak time?
According to my router stats, the noise margin is 6.9, line attenuation is 58. Could that be causing the problem, and is there anything I can do about it? It never used to be this bad - and even now, there are times when everything's just perfect and there are no speed issues at all.
It's so frustrating! If someone could at least point me in the right direction to start investigating...
