Connection problems CellC network - White River
Venom Maker
Nelspruit
I am located in White River the new coverage area of CellC in Nelspruit does not reach my area. Vodacom, MTN and Telkom 3G all have a strong 3G signal in my area however I am connecting on Edge only via the CellC's network. Is there anyway I can force the modem to connect via one of the 3G sites onto the CelC network?
:confused:
Did you buy one of the new promotional modems or SIMs or are you using your existing CellC SIM?
Then your only other option is a high gain antenna to see if you can get signal but if you are too far out of the coverage area that won't help.
I was wanting to test the 3g signal before buying, using a friends Huawei K3565 and my existing cell c prepaid sim. Are you saying I will not get the same result as the new promotional modems or SIMs?
Correct, only the new data promotion SIMs are provisioned for the HSPA+ network.
You can get CellC guy to come & do signal test for you.
Ask nicely at your nearest store, thats how i did it ;)
