EDGE speed tests in Stellenbosch
johandutoit2000 said:
I am connecting to the Stellenbosch tower. It says Y'ELLOW BROADBAND on my phone (Nokia 6220 - EDGE capable). The highest (not even the average) download speed I get is 62kb/s. What is wrong? I tested 2005-09-23 11:34 AM.
I am using USB to IrDA device. Throughput of Nokia IrDA - IrDA - USB is 115kb/s if anyone thought that could be the limiting factor.
AFAIK there are only 2 EDGE towers in Stellenbosch, this is according to MTNBB in April. He said they are BJ Vorster and Helshoogte koshuis. I tested EDGE speeds tonight on the Helshoogte tower (channel 108) using a 6680. EDGE speeds are as "advertised"
, at least where I am. My results are as follows for the Telkom http speed test.
-75 dBm (10x stronger than full bar of -85dBm) -> 165 kbps
-95 dBm (about 3 out of 7 bar) -> 110 kbps.
-100 dBm (2 out of 7 bar) -> 97 kbps
-104 dBm (1 out of 7 bar) -> 45 kbps
So it would seem that with even 2 bars, EDGE outperforms GPRS and GPRS+ speeds. Those guys not getting the speed, its either a congested tower/time, or you are not getting 4 timeslots for download, or your handset does not support 4 timeslots for download. The Nokia series 60 handsets are great for monitoring data throughput.
I'd be interested to see other forumites do the same test, especially those who get signal strengths stronger than the best I can manage (without going through a lot of hassles getting an external antenna).
Best to test with a Symbian phone with the field test menus and lock the phone to the EDGE tower using menu 1.12 of field test. Then monitor the timeslots and signal strength on menu 6.1.
To make the signal weaker, move the phone around, or best, put it in between your legs
