Connection very slow - need help.
comfort
Hello iBurst’ers,
I am hoping one of you kind souls can explain the following to me:-
1. Why my download speeds never get faster than 50kbps?
2. Why I cant stay connected to the Fourways (Indaba) tower for more than 5 minutes (when my signal strength is between -65 & -72 on utTraceStar) without re-connecting to a tower in Auckland Park or Kyalami Castle (where my max connection is -105). Why would it want to connect to another tower when Fourways (Indaba) is so strong?
I have an antenna (from phoenix.net) and it is pointing directly to the Fourways (Indaba) tower.
utTraceStar tells me the tower loading is between 2-3.
When I connect to the Umhlanga Ridge tower in dbn my strength is around -89 but I can download around 100kbps mark (and the tower loading is 2).
I would be much appreciative of any help.
Thanks,
Shaun
are you using the Ethernet Cat5 cable?
I've had a problem with the cat5 cable when connecting to iburst until I swopped out my router...
thanks for the response, i just use a regular usb cable, no router. this used to work a treat until a couple of weeks ago???
