Connectivity Problem
daffies
Hi, I have a computer with Windows XP Professional and Windows 2000 Server dual boot.
I have installed the my wireless modem on both operating systems and I experience the same problem on both operating systems.
What happens is that after being connected for 2 min, I get no data throughput although I am still connected.
When I am downloading a file, it stops downloading and then comes up with a timeout error. The funny thing is, that I am still connected, I then have to manually disconnect and re-connect, then it works for about 2 minutes then start with the problem again.
I tried re-installing the drivers about 5 times on each OS.
Does anybody have any advice?
Thanks,
David Reid
When this happens, try removing the USB and then putting it back then logon again.
What tower you connected to and whats your signal strength.
