RetroRabbit
- Oct 3, 2019
Has anyone paired a connex device like this to home assistant? I can't really find anything about it on the internet and I would really love that door contact for my home assistant to act as an alarm.
Unless someone has a better product/suggestion on how to do the door sensor.
Looks like it will work with home assistant! Thanks man!Have you looked at Wyze Sense? Tiny sensors that integrates into Home Assistant via the included USB hub.
Check here.
I bought a Connex SmartPlug for some power monitoring earlier in the year and initially did not see any way of integrating it in Home Assistant. I then read that the Connex devices are basically Tuya rebranded.Has anyone paired a connex device like this to home assistant? I can't really find anything about it on the internet and I would really love that door contact for my home assistant to act as an alarm.
No, but I managed to integrate a Connex Multicolor Bulb using Tuya Local on HA. I 'assume' it should be possible to do the same for this.... These sensors are just a little expensive... I use the Sonoff DW2 to monitor my doors for now (about 50% or more cheaper than this)Has anyone paired a connex device like this to home assistant? I can't really find anything about it on the internet and I would really love that door contact for my home assistant to act as an alarm.
