Console sound adapter
Ghost02
CPT
Hi, so today I bought myself a 22" lcd monitor (using it now :p) and some cheapish logitech speakers. Now I see kalahari.net has vga cables for R184 but I'd like to get it tommorow, where could I find a generic in Durban? Also I need one of the logitech console adapter so that I can use these speakers with my xbox. I never got an adapter with it, where could I find one?
you should have received one in the box - otherwise go to the store you bought them from and ask them for it.
The logitech is 360 compatible.
I only saw afterwords on the box that it says "requires game console adapter" in microscopic writing.
hmmm...just check as I thought the adapter is included...I was going to pick up some speakers this weekend...
Well I didn't buy the high quality 5.1 speakers. I only bought some x-210's
The low end ones don't come with the adapter. My X-530's in my bedroom did however :p
You'l just have to look around for an alternative adapter dude
Ghost02, this weekend, I found the solution. This will work for headphones too with a twist.
Go and buy RCA female into stero jack adapter - I got one at a computer store (NOT incredible connection) for R9.
That is the adapter that you require to use your speakers for the 360.
In order to use your headphones for your 360, normal headphones, use the same adapter and then get a female jack adapter, you can now plug in the headphones onto your cables directly. :D
