Prof.Merlin
Hi All
We are having constant issues with our asterisk box. We either have dropped calls, or a lot of one way voice.
Specs on the machine is 2 x X3430 @ 2.40ghz with 12GB memory. We are running 2 other services on the same box, but will be moving off soon.
We have tried 3 different connectivity options, now running with neotel 15mbit fibre. Pings run between 3ms-6ms to Centracom(our sip provider).
We have run the dahdi_test and got the following results:
We are running with a Sangoma A200 card.
In our trunks, under outgoing, we have:
allow=g729
and incoming we have:
disallow=all
allow=G729&alaw&ulaw&gsm
qualify=yes
We have a digium G729 codec.
I am not sure what other info I can give.
Our phones are all set to use different codecs, would changing them all to G729 make a difference?
Thank you
Code:
--- Results after 435 passes ---
Best: 100.000 -- Worst: 99.612 -- Average: 99.993044, Difference: 99.997798
allow=g729
disallow=all
qualify=yes
Thank you
