cooler master cm690 vs scout
nelis
Hi there. What will you guys prefer. The scout is bit more expensive than the 690. I;m only going to run basic intel dual core, 1 HDD, 4850, dvd drive, etc etc.
The cm690 is cheaper but will the scout cool better? I don't worry that much about looks.
The scout's cooling is pretty decent, 3 stock fans 120mm - 140mm and option to add additional (on the side panel) taking into consideration your cpu cooler is under a certain height, less that 20cm.
My choice in the scout was a combination of things...looks, functionality, space, practicality etc, so I think it was a awesome choice. Then again you're not into looks, so it might rule the scout out there a bit
I would probably opt for the 690 in your case, no pun intended :D, it has option for further cooling and is very similar to the Scout and also much cheaper.
The scout has a handle. For a lanning case, it's awesome.
Ye, if you lan a lot get the scout. If you don't lan or don't lan often, get the 690 :)
O forgot to mention. I got a thermaltake carrybag
Both cases are pretty good. it just comes down to which one will benefit you the most.
http://www.bit-tech.net/hardware/cases/2009/05/08/coolermaster-scout-review/1
The Scout is a tough case to judge because, while it has its undeniable flaws, it also packs enough major positives to set itself out from the myriad of similar "gamer" cases. For one, the LAN party features of a sturdy, strong case handle and securable peripherals make it an ideal choice for the hardened LAN attendee, and those who frequently pack up their PC and kart it around the country will doubtless see these as major advantages.
Innovation is a rare trait when it comes to cases, and it’s good to see Cooler Master still looking for ways to make its cases unique, rather than rehashing parts from other products.
The chassis build quality is also commendable and once again Cooler Master has shown us it really knows how to put cases together. The whole thing feels tough, hardwearing and sturdy, with no noticeable gaps between panels and fascias, be they plastic or steel.
However, the solid build quality isn’t an ever present in the Scout, with the dreadful expansion slot toolless fittings becoming an easy annoyance that we eventually abandoned for the spare thumbscrews that Cooler Master mercifully includes. The 5.25in drive bay toolless fittings are also cheap and flimsy compared to what we’d usually expect from Cooler Master and while ultimately functional, they weren’t great.
Cooler Master Scout Final Thoughts Cooler Master Scout Final Thoughts
Click to enlarge
Finally the lack of any real space to stash unwanted PSU cables is also a notable gripe, although this is lessened by the brilliant pre-tidied front panel cabling that runs down behind the motherboard tray.
For all its flaws and qualities though, it’s performance and price by which the Scout will be judged by many, and unfortunately it doesn’t come up too well on either front. While commendably quiet, out the box the Scout’s cooling is hit and miss (hit for the CPU, miss for the GPU) and would really have benefited from a fourth 120mm cooling fan fitted into the side panel. Of course, you can easily add this yourself (Cooler Master even includes the self tapping screws), but it’d be unfair of us to judge a product based on what you can do with it rather than what it does, even if 120mm fans can cost very little (or a lot if you buy a Noctua).
It’s the price that’s a real concern though. At £104 it’s currently more expensive than the Cooler Master HAF 932, which can be just as quiet, and cools much better, and its main competition, the Antec Nine Hundred Two, which while louder, offers brilliant cooling and better all-round build quality. It’s a shame as, for £70 or £80, the Scout could have been seen as a cheaper yet almost as capable version of these two very popular cases with some distinctive genuine gamer-centric features, but instead struggles to justify its high price, despite its unique selling points.
http://www.bit-tech.net/hardware/cases/2007/11/29/cooler_master_cm_690/1
Conclusions
That table brings our testing section a close and now all that is left is for me to summarise our findings, wrapping it all up nicely before the folks at Cooler Master come and demand that I return to them the rather nice CM 690 chassis. My time with it has been short, but memorable.
The Cooler Master CM 690 is a nice looking case, there’s no doubt in my mind about that, and the fact that its available for around fifty quid in the UK only sweetens the deal. On top of that, the cooling performance is pretty admirable.
Cooler Master CM 690 Results Cooler Master CM 690 Results
Click to enlarge
Does the case have problems? Sure it does, but nothing is perfect. The plentiful ventilation grilles mean that the case can get pretty noisy, especially if you have it on your desk right next to you monitor. That’s only going to get worse the more fans you put in the case too, though it can also be solved pretty easily by putting the case in a desk alcove.
The main problem with the case though is the apparent flimsiness of the material and the fact that the build quality is occasionally a little suspect. The front of the case doesn’t meet the side panels or the top of the case all that well, even on the side that I didn’t damage.
Regardless, the Cooler Master CM 690 is still a very worthy addition to the catalogue and the cheap price means that pretty much anyone can justify the expense. It may not be the most flash case we’ve ever seen, but it does what it says on the tin and it does it well at that. There’s not much more you can reasonably ask for.
The Scout looks great, but the CM690 is easier to build into and neater. Scout is very tight inside (hell, a CM Elite is probably bigger :rolleyes: :D). Scout has no behind-the-backplate cable management. I also found that some of the fan wires in the Scout were too short.
I think I will still go with the cm690. I will see at rage when if I can get the cm scout for a decent price. cheapest so far is at take 2 for R1122. I will also check the cm690 at rage.
The pc I'm building is a budget pc so the more money I can save the better. O and how does the cooling compare on stock. cm690 comes with (1x side, front, back), scout(1x top, back, front).
CM690 fans seem to be of a higher RPM. Never really checked properly though, plus I run my CM690 without a side panel. I'm sure there will be plenty of cooling for your "budget" PC. :p
Speaking of budget, have you considered the CM Elite chassis? The new Elite 310s look nice and would be perfectly adequate for your PC.
hell you can take any case but stay far away from the cooler master ammo. that is the epitome of ugly
Will the elite 310 fit a 4850. will the cooling be good enough. looked up some reviews and it looks a bit cramped.
I think I shoul go with the scout for a change. I already got a cm690 and I though today that I want something different. I will have to wait till rAge is on to see what the prices is there. Last year I bought by cm690 for R850 and it was like 2 - 3 weeks later at rAge for R650.
I disagree completely, the 690 is classy :)
Just remove the honeycomb pattern in front of the LED fan (easily removable as far as I can see) and it will look much better.
