Cooler Woes...
Cheaper than R300? Any links to back that up? :D
From what I have seen, these coolers perform the same as the Freezer 7 Pro.
My bad, was thinking of some overpriced thing..
[edit: well you're getting a VERY good price on that as they can be found as high as R374 - R468.00]
But ye Freezer 7 Pro, or Hyper TX 2..
hyper tx2 is a very good budget cpu cooler, would recommend it to anyone lookin for extra cooling but who aint gonna do some hardcore overclocking.
but your e8400 is begging you to push her to 4ghz :P
LoL, not to much worried about the E8400 now, which is also still on stock cooling. :eek:
It's the E6300. 1.86Ghz is a bit low, so I want it on 2.8Ghz, cause then Crysis should run much better. :D
