COOLERMASTER SICKLEFLOW 120 TRANSPARENT BLUE FAN
kaisterkai
Good day
Have anyone used one of these?
Cause I'm planning to get one, but the thing is that I dont' have a 3-pin on my MB.. so i was wondering all that comes with the fan and is this can silent?
Is anyone know, advice would be great..
Thanks~
I've got the two that aren't transparent, I have a fan controller for them, they pretty quiet even with a fan filter in front of it.
You either get a converter cable 3pin to molex or get a fan controller.
Trying to get it from Cafe Viva..
but they said it doesn't .. :(
Does anyone know where I can get these 3 to 4 pins molexes?
Hey kaisterkai,
I got myself 2x Red sickleflows for my raidator for my Corsair H50-I for the Push Pull method.
As you can see below in the link it has a 3-pin connector.
Not sure if ALL come with it but thats what came with mine.
Want to get the blue now and change me HAF X into a blue system cause I'm bored of the red lol
But ye comes with a 3-pin connector.
Pictures:
Hey kaisterkai,
Yeah I got those also, they push an insane amount of air for the amount of noise they make, anyway I rate you should rather get color shifting fans hey if you get bored of a color like you are now.
Mind sending me a link on those :D
I tend to keep with Coolermaster fans and would love to stay with the black "frame" for the fans.
Went with these cause of the black + red which was the theme I went with for the Rampage 3 Extreme :)
But ye if they really good fans please send me a link of them so I can see.
The other fan that caught my eye on getting was this: (still red but like that design)
Coolermaster Xtraflo Red LED
Hey kaisterkai,
Pictures:
I see..
Ok.. Thanks
but does it come with a 3-4 pin molex? Converter thingy?
Yeah... My case is currently all blue.. so was thinking about getting one of the blue ones :)
So they are quiet?
Mmm.. Was thinking about the noise.. Anyway.. thanks.. Think I made up my mind to get one of these.. Just have to find a converter for the 3-pin
yeah.. I actually saw this on the CM website..
It does look awesome..
But at the shops near me.. They don't seem to have any of them :(
I can't remember if it was from the Sickleflow or if it was from the Coolermaster megaflow that I got these.
Got them (the fans) last year November.
But if it doesn't come with (which I'm sure it will cause it will explain why I have some left over) send me a PM with your details and ill send both off to you at the end of the month.
Thanks alot~
Will do :_)
Ye not gonna argue there but I bought 5 x fans
3 x MegaFlow
2 x SickleFlow
I only needed to use those converters on the Megaflows where as my SickleFlow just connected to the fan connectors on my board. I have 2 left over, so I'm thinking I must have gotten some with the SickleFlows.
Also I remember thinking to myself, the SickleFlow had better quality 4 pin molex - cause when I tried connecting it to the PSU connector one of the pins would pop out and I would have to push it back in - not saying I was doing it 100% correctly but it never happen on the SickleFlow ones.
When you get your fan kaisterkai just check right at the bottom of the packet where you find those screws.
3 x MegaFlow
2 x SickleFlow
I see.. mm.. I'm thinking now.. Does the sickleflow make alot of noise?
Cause I was actually was going to get one today. but then thought if I got it.. and can't use it.. Then what lol..
But anyway.. ok.. since you say that now.. i think I'll go into the shop and ask them about it :)
But actually I have another fan in mind..
It's the CM value pack.. It has 2x 120mm fans.. Cheaper, and it's still the same..
But it doesn't come with the 3-4pin thingy.. so yeah.. :(
Get Megaflow fans, cause you need the adapter that comes with them. Don't worry about the noise they make. Read up on some reviews (if any) on Megaflow noise levels and decide for yourself.
Megaflow fans are only 200mm + my case can only take 80 and 120.. Which is sad.. But it's ok.. :)
