Correct SMTP Settings required for Axxess for use on Mweb
PaulB_
Hi all.
As the title describes, I am looking for the SMTP settings so that I can get my Axxess email settings working via Outlook. I use Mweb as my home ISP, however I still my axxess emails.
There is nothing on the Axxess website which gives any mention of POP settings.
Afrihost, which to my understanding owns Axxess said mail-my.cupcakes.co.za needs to be used in that situation, however that server doesn't even resolve.
It was working before I went to New Zealand for 9 months, but changed it as was unable to send any emails, even with sever Authentication enabled, now I am back and cannot for the life of me find the correct combination to get this working.
Any assistance will be greatly appreciated.
Good day.
Axxess incoming mail settings:
Pop3 mail.axxess.co.za
Port 995
SSL/TSL No
Use your axxess.co.za username and password
Outgoing mail settings:
Server smtp.axxess.co.za
Port 465
SSL/TSL No
However, since you are using mweb as ISP, you might have to change the Smtp settings to smtp.mweb.co.za in order to send emails using your axxess email address if the axxess.co.za smtp settings does not work.
Server smtp.mweb.co.za
Port 587
SSL/TSL No
Use your mweb email address and password
You can also ask @Captain Axxess for assistance.
Hope this works for you.
Have a good day.
