Correct usage of <article>, <aside> and <section>
Thor
Bellville
I need some help.
If I want to build a one pager for example which of the two would be correct and why.
My current approach:
HTML:
    <nav class="navbar navbar-custom navbar-inverse navbar-static-top" id="nav">
        <div class="container">
          <div class="navbar-header">
            <button type="button" class="navbar-toggle" data-toggle="collapse" data-target=".navbar-collapse">
              <span class="icon-bar"></span>
            </button>
          </div>
          <div class="collapse navbar-collapse">
            <ul class="nav navbar-nav nav-justified">
              <li><a href="#">Home</a></li>
              <li><a href="#about-section">About Us</a></li>
              <li><a href="#gallery-section">Gallery</a></li>
              <li><a href="#howto-section">How-To</a></li>
              <li><a href="#contact-section">Contact</a></li>
            </ul>
          </div><!--/.nav-collapse -->
        </div><!--/.container -->
    </nav><!--/.navbar -->
    <!-- Container -->
    <hr class="about">
    <!-- About Us -->
    <section id="about-section" class="about">
      <div class="row">
        <div class="col-lg-8">
          <article class="primary-about">
            <h2>About Us</h2>
            <p>Lorem ipsum dolor sit amet, consectetuer adipiscing elit. Aenean commodo ligula eget dolor. Aenean massa. Cum sociis natoque penatibus et magnis dis parturient montes, nascetur ridiculus mus. Donec quam felis, ultricies nec, pellentesque eu, pretium quis, sem.rhoncus ut, imperdiet a, venenatis vitae.</p>
            <p>Lorem ipsum dolor sit amet. Donec pede justo, fringilla vel, aliquet nec, vulputate eget, arcu. In enim justo, rhoncus ut, imperdiet a, venenatis vitae.</p>
            <p>Lorem ipsum dolor sit amet, consectetuer</p>
          </article>
        </div>
        <div class="col-lg-4">
          <aside class="secondary-about">
            <h2>lorim Title</h2>
            <ul>
              <li>Lorem ipsum dolor</li>
            </ul>
          </aside>
        </div>
      </div>
    </section>
    <hr class="gallery">
    <!-- Gallery -->
    <section id="gallery-section" class="gallery">
        <h2>Our Gallery</h2>
              <p>lorim</p>
            <div class="row">
            </div>
    </section>
    <hr class="howto">
    <!-- How To -->
    <section id="howto-section" class="howto">
      <div class="row">
        <div class="col-lg-12">
        </div>
      </div>
    </section>
    <hr class="contact">
    <!-- Contact Us -->
    <section id="contact-section" class="contact">
      <div class="row">
        </div>
      </div>
    </section>
    <!-- End of Container -->
    </div>
    <!-- Footer -->
    <footer>
        <div class="row">
            <p class="text-center">Lorim</p>
            <hr>
            <p class="text-justify">More Lorim</p>
          </div>
        </div>
    </footer>
This is the other approach I had, but makes less sense to me:
HTML:
            </button>
          </div>
              <li><a href="#about-div">About Us</a></li>
              <li><a href="#gallery-div">Gallery</a></li>
              <li><a href="#howto-div">How-To</a></li>
              <li><a href="#contact-div">Contact</a></li>
            </ul>
    <!-- Container -->
    <article>
        <hr class="about">
        <!-- About Us -->
        <div id="about-div" class="about">
          <div class="row">
              <div class="primary-about">
                <h2>About Us</h2>
                <p>Lorem ipsum dolor sit amet, consectetuer adipiscing elit. Donec pede justo, fringilla vel, aliquet nec, vulputate eget, arcu. In enim justo, rhoncus ut, imperdiet a, venenatis vitae.</p>
                <p>Lorem ipsum dolor sit amet, consectetuer adipiscing elit. Donec quam felis, ultricies nec, pellentesque eu, pretium quis, sem. Nulla consequat massa quis enim. Donec pede justo, fringilla vel, aliquet nec, vulputate eget, arcu. In enim justo, rhoncus ut, imperdiet a, venenatis vitae.</p>
                <p>Lorem ipsum dolor sit amet, consectetuer adipiscing elit. Nulla consequat massa quis enim. Donec pede justo, fringilla vel, aliquet nec, vulputate eget, arcu. In enim justo, rhoncus ut, imperdiet a, venenatis vitae.</p>
              </div>
            </div>
              <div class="secondary-about">
                <ul>
                </ul>
              </div>
            </div>
          </div>
        </div>
        <!-- Gallery -->
        <div id="gallery-div" class="gallery">
            <p>lorim</p>
            <div class="row">
            </div>
        </div>
        <hr class="howto">
        <!-- How To -->
        <div id="howto-div" class="howto">
          <div class="row">
            </div>
          </div>
        </div>
        <!-- Contact Us -->
        <div id="contact-div" class="contact">
          <div class="row">
            </div>
          </div>
        </div>
        </div>
    </article>
    <!-- Footer -->
    <footer>
        <div class="row">
            <hr>
          </div>
        </div>
    </footer>
Please help me understand how to use these bad-boys correctly?
To me , first way .
Gallery could be an <aside>. Inside that aside each gallery item could be an article, in that articl each picture could be a <figure> , title could be <figcaption>
nav could be further wrapped in <header>
