I have a 2001 1.4i Corsa Light. Just replaced Clutch, Pressure Plate & Release Bearing (LUK), now the vehicles starts up when your clutch is pressed down.
Prob 1: I do find some gears but the reverse lights stay on even though vehicle is not in reverse.
Prob 2: Wheels keep turning even in neutral with foot of clutch and reverse light still on
We have have set the gear linkage to spec
Oil Level is 100%
Cable 100%
Reason for replacing is Clutch Plate one Tension Spring came out (Fong Kong Parts)
Did not open the gearbox did not see use of that for broken clutch
I'm doing this myself with some help don't have monies for specialist or mechanic
Any help will be much appreciated
TheNoobMechanic
Oil Level is 100%
Cable 100%
TheNoobMechanic
