Cost effective IPTV to CATV solution for viewing on multiple sets in house.
PaulB_
Hi all
Been thinking of starting with a fun project which involves setting up an in house analog cable TV system that will allow me to view a certain amount of my IPTV streams on multiple devices in the house.
The issue is how would I go about getting devices cheaply which will allow network connectivity which allows loading of a playlist. I was thinking of one device per Channel, which obviously is going to be extremely expensive. I was thinking of using a camera capture card with multiple inputs, which would have been nice as it would have. Been cheap, and I could have one channel per "input" till remembered that a camera card is input, and not output which obviously is what is needed here.
Obviously then it would needed to be sent from that device to a modulator. Which isn't a problem. The markets such as Milnerton & Muizenberg are flooded with ex M-Net comcrypt 4000 decoders which have an AV input which can probably be picked up for less than R100 each. Which serve no purpose other than being ideal to convert AV to RF. So for 5 channels, 5 M-Net Decoders connected to whatever is being used to feed the signal via AV. Just need something cheap which will let me feed an IPTV signal to AV.
Hi all
Why would you want to downgrade to analogue?
Get an old cheap pc and slap a linux os + jellyfin on it. Or even run it off an existing pc. Add you iptv url/file to jellyfin. Load some jellyfin clients to your smart tv's to access any channel...and any other content you add to jellyfin server.
If you want to play the same stream from a tv box on multiple screens, a hdmi distribution box (with the appropiate home wiring) is your best bet.
Or you can modulate a tv box hdmi signal to dvb-t, and use digital tv tuners, if you tv's have them. Spacetv sells these for roughly R4000-R5000. Only 1 channel can be watched on all tvs.
I use jellyfin with a m3u file i made for just some iptv news channels. It gives me extra flexibility to watch any channel on any screen...tv,phone,tablet. I can record doccies in the background and watch from any screen.
Epg for easy recording
It runs from a pc in the study. At the beach house i use Kodi for iptv functionality. Channels load faster in Kodi.
