Costs for PVR + dual LNB installation
missionimpossible
I'm considering upgrading my existing DSTV Subscription.
I'm currently paying R559-00 for the standard DSTV.
When I called DSTV, they advised me that it costs an extra R65 per month.
This is after the installation is done.
I have seen some specials for a PVR decoder cisting R1499.
Does anyone know what does installation for a PVR + dual LNB cost?
what other costs are there?
Does it cost extra to hook up the HD channels?
Well generally a 2P PVR is R1499, i have seen them on special for around R1399/R1299 but only once or twice.
A dual LNB is around R300, try hdcabling.co.za
then it is a case of running another cable so either DIY, cable costs around R3 p/m or get a guy to come do it at probably around i would guess R450ish depending on the run.
if you DIY just make note of how the current LNB is angle wise and put the dual on the same.
no the HD channels wont cost you anything extra they are included when you have the PVR with the premium bouquet
