Could my router be limiting my speed?
Darren_Ford
HI All
I have recently upgraded my adsl line from 4mb to 10mb, when doing a speed test i get the same 4mb speed i was getting.
I have logged several calls with Telkom they say that everything is 100% on their side.
The router I have is a TP-Link W8960N router, could this be the reason my speed is staying at 4mb?
It is relatively old and is on the latest firmware but i thought i would check before buying a new one.
Thanks in advance
Regards
Darren
Did you upgrade your ISP account?
What does your router say about sync speed, attenuation and SNR?
I know distance to exchange etc. can impact this but surely I should get a little more than i used to get?
Hi there MickZA/Joker thanks, it's the 10mb uncapped package.
Did telkom phone to confirm that the upgrade was completed? sometimes there is a lag between the line upgrade and data uprade
Just spoke to them again and they confirm all is 100% line and package refelct 10mb on their side.
I'ts been like that since i upgraded 2 weeks ago. :(
try switch off and unplug your router for 10 minutes.
Sorry, it was a bad link. You'll see I edited it in my post.
Hi MickZA, THANK YOU, after 2 weeks of struggling the prioritization was set to 4mb i changed it and boom 9.1mb on the speedtest.
Thank you so much i should have asked the gurus on here earlier !
You sir are a gentlemen and a scholar, and have made my day!
