COZA: FAIL: Can not decode base64 issues.....
jack_spratt
London
I am trying to update a co.za domain using the standard form, however when i send via gmail I get an error email from co.za with the following message:
But I do send plain text??? What gives?
The mail is encoded when you pass it through dovecot or phpmail (the mail app), you are sending utf8 or utf16 characters, the encoding might be funky, or the signatures are failing.
I suggest sending only numbers as a test, then work up from there. Either that or ftp in and do it that way. So the server can read it from local disk.
