Create Repository CD/DVD
Sysem
Here's the situation, currently I have a nice Ubuntu setup, working perfectly. My friend, however, has a fresh install of 10.10 but with no internet connection at all. Is there anyway I can create a repository DVD of my libs and packages currently installed for him do use?
I've tried AptOnCD but that only put packages stored in my apt cache, so it failed miserably. Any other suggestions?
Thanks,
Sysem
Buying repos is out the question, he'd rather use his Windows partition if he has to spend money. Just thought I'd help him out.
Understandable.
The easiest thing I could suggest is take his pc and update it from your line?
Understandable.
Probably the hardest :p I take my laptop to campus for internet. He has a desktop. He'll probably have to wait for Telkom to get their butt's into gear.
In that case let him use windows. If he does not have internet and not prepared to pay a minimal fee to cover the media then he must maar suffer.
The he's fooked using Ubuntu or Windows.
Only way is to buy the repos on DVD or go to a university and mirror them from TENET which will be fast http://ubuntu.mirror.ac.za/ubuntu/dists/
Well not for Windows. At least then he can take his portable HDD to someone with internet access and download his VLC, iTunes etc. There's no need for dependencies. But not a bad idea mirroring them from TENET from UCT. Will let him know.
Is think there is a way to:
- Get updated repository list on connected PC. Copy and take this list to offline PC.
- Offline PC use this updated list to compare with current setup and print to file a list of required files.
- Take required file-list to connected PC and download it. Copy all files to external disk (USB/other).
- Make a packages.gz(?) file of the newly copied files, add USB/other path to sources.list and update the offline PC.
I read about it somewhere.
