Creating a file index system
Nom Chompsky
High Tory
So this is what I want to do...
Basically six different people will be emailing me documents in a word document, on a frequent occasion.
Now what is contained in these documents are motions (as in a board motion).
Now what I intend to do is rank these motions (this part is not the problem) according to a particular set of criteria (i.e. so say I get 2 motions from each group, I will need to rank them from 1-12). I intend doing this using excel using an algorithm I have created.
However, the person in charge would also like an automated index system so I don't miss any motions (thereby potentially messing up the rankings). The obvious problem is that these motions will be sent in word, but I will be doing my ranking via Excel.
I am not sure how to start thinking about solving this problem.
Wouldn't it be easier to just label and categorise all the sand on all the beaches around the world? :eek:
Can't you set a rule for it to save attachments from certain people?
Alfresco has workflow features so you can receive a document by email (I think) or into a shared folder then it can be routed automatically through a review process eg. pending >> document checked out (by you)>> ranked(in your spreadsheet)>>moved to 'reviewed' folder when complete.
There is a simple/adhoc workflow set up and a more fancy, complicated type workflow if you're so inclined. You should be able to use the simple worklfow to track which documents you have ranked, still need to review etc.
