Crossover Cable for PC
Easiest thing in the world to make though :)
Does it even have to be a crossover?
Well he said PC to Xbox,so no mention of switch,does the Xbox have auto-sensing ports? 0.o
Dont most PCs? You only need auto switching on one end.
If you can pick it up, I will make it. :D That is, if you want to wait that long? Where are you now, if you aren't working and where is the west rand, I am new to joburg. :o
I would forever be grateful. Can kick my own butt for losing the one I had :(
I'm in Wilgeheuwel (close to Clearwater Mall). But it's not death matters, I just wanted to get the ball rolling so long. :)
PS, thanks for helping out the damsel in distress. :p
Hi Guys,
Where can I go to get about a 6m crossover cable to link my PC to my xbox 360?
I lost the one I had :(
um, you take out your network crimping tool, you cut about 6 m of UTP cable off the roll, grab two RJ-45 plugs and saddles... and get to work! :D
Just remember to put the saddles on before you crimp the RJ-45 plugs onto the end of the cable :o
