Curve 8900 GPS Navigation maps
Freeksta
Hi There,
I've signed myself to the Blackberry side... :)
So far so good, went with the Curve 8900, as it's smaller and after much review, the speed differences arent too much for me to notice...
I however am having some issues trying to learn how to setup the GPS Navigation.
Maps??? activation??
Also any free apps world sites I can join???
thanks alot...
Make sure your BIS/BES is active with MTN :sick:
If it is, then look for the SatNave icon on your menu screen. Select it and it will download and install. Happy navigating.
MTN do not do SATNAV, they went the Garmin route.
You can access it via the menu function *123# (I think MTN uses 123)
A sms will then be send to you with the url for download
