I have created several port forwards (under virtual servers) for a PC, specifically for ssh (port 22) and apache (port 80). I have also acquainted myself with other 2650U/port forwarding threads on the forum (Port Forwarding on D-Link DSL-2650U router?
The PC is visible through ssh (i.e. the port is correctly forwarding). However, when I add a web server port forwarding rule, because the router has its web interface bound to port 80 as well, it gives me the following message:
"Since port 80 is used, the DSL router WEB server will be moved to port 8080."
Which is perfectly fine, but requests on port 80 still route to the router's web interface, asking for login credentials.
I'm unsure if disabling the web interface from remote access will resolve this issue- or indeed how to do so.
Any help would be greatly appreciated
